FPGA not launching configuration from EPCQ128A device.
- 7 years ago
Hi CSegu,
Happy New Year to you. Which Quartus Prime version are you using to generate the .jic file for EPCQ128A? The Quartus Convert Programming File setting screen shot that you provided was set to EPCQ128 which is a different flash from EPCQ128A device. In AN822 document has mentioned the EPCQA flash device are supported starting from Quartus Prime Standard v17.1. Thus you should be using Quartus Prime Standard v17.1 above to generate the correct programming files for EPCQ128A device.
https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/an/an822.pdf
Nooraini
Dear Nooraini,
I have attached files via email. Now I am attaching them again here. Yes I know that JTAG is different from ASx1. I have set ASx1 also in Device Pin options.
Thank you for your help.
Clive
Hi CSegu,
Nooraini
