Amelkai
5 years agoFPGA multiple firmwares on one serial flash memory
Preloaded more than one firmware to flash memory.
Can I make the FPGA reboot during its operation and start loading its firmware not from the beginning of the flash drive, but from a different memo...
YuanLi_S_Intel
5 years agoHi,
Just would like to clarify with you. When you said about download firmware, are you referring to the design generated in Quartus?
Bruce
Amelkai
5 years agoYes. I generate two different .sof files for one crystal. Then generated two .rpd files. Programme flash memory using these two .rpd files. The second is with an address offset. (It doesn't matter which way to loaded the data to flash memory)
On power-up, the first firmware for FPGA will be read from address 0. And the FPGA will work as the first project was conceived. Is there a mechonism with which you can configure FPGA with the second option, third and next..? Offset boot load may be..
