11 years agoFPGA is not responding to code
Hello, I have downloaded vhdl code in cyclone III fpga. But fpga is not responding after downloading. I have two vhdl codes. When I download first vhdl code, fpga works fine. But when I downloa...
11 years agoWhat is all this talk of breakpoints, signaltap etc?
Surely the OP had a good testbench - did the second set of code pass through the same testbench as the first code? If you want some help with a problem - you need to post the code so we can actually help.
