11 years agoFPGA is not responding to code
Hello, I have downloaded vhdl code in cyclone III fpga. But fpga is not responding after downloading. I have two vhdl codes. When I download first vhdl code, fpga works fine. But when I downloa...
11 years agoIt sounds like your 'modification' to the second code breaks it functionally. If it's using up fewer resources than you expect then something's wrong. I suspect you've made a small error in your code that results in a portion of functionality being removed. Hence, it's not as big as you're expecting nor does it do as you expect.
Do both design simulate as you'd expect? I suspect not... Cheers, Alex
