16 years agoFPGA is hot
I'm using EP1C6Q240 FPGA, after programming it , the current for 3V3 was about 400mA, working OK, after several weeks, the current went to about 800mA and FPGA was getting hot, but it's still working...
16 years ago --- Quote Start --- There are two issues, that are likely to cause excessive current consumption: - floating input pins Clock pins don't have an option to set a defined level by configuration and must be externally terminated. Other unused pins should be e.g. configured as input with weak pull-up. - shorted output pins --- Quote End --- Hi! FvM! You said that "shorted output pins" is a possible issue to cause excessive current consumption . I can't undersant that . can you descript it in detail? many thanks!
