15 years agoFPGA IO configed as 1.8V not working
Hi, I read from the device handbook and get that the cyclone2 devices support multi-voltage IO standards, such as 3.3/2.5/1.8/1.5 volt. I change the IO voltage to 1.5 volt in the device option...
15 years ago --- Quote Start --- The I/O voltage setting has the purpose of informing Quartus about the hardware enviroment. The actual voltage is set by connecting the VCCIO pins to a respective supply. Apparently your board (I guess, a development kit) has all or most VCCIO pins wired to 3.3V. --- Quote End --- Does the IO voltage setting have purpose other than informing quartus? eg, if I want to use max-ii device as level shifter, but one side of the shifter's voltage is variable, you know... so I hope the IO voltage setting has only information purpose. then i can chose one setting and change VCCIO without re-compile
