12 years agoFPGA external reset
hi, I am using Cyclone III,and I'd like to have my own external reset.but I am not sure when to safely insert external reset ASAP. Do I have to use it after CONF_DONE goes high? i...
12 years agoMux and Dave,thanks a lot. it's a new design,I plan to route CONF_DONE to reset supervisor manual input. The "standard" gives me more confidence:_),although I noted http://www.ovro.caltech.edu/~dwh/car...0.87_dec03.pdf is mentioned several times in different threads.
I still want to figure out how to understand "all I/O are tri-stated when configuration", Does it mean external POR can't enter FPGA when configuration, or it enters,but has no effect on FPGA configuration? can you help with this?
