12 years agoFPGA external reset
hi, I am using Cyclone III,and I'd like to have my own external reset.but I am not sure when to safely insert external reset ASAP. Do I have to use it after CONF_DONE goes high? i...
12 years agoHi,Mux,
thanks for your suggestion, I know from your answer there are two ways to do so. One is to apply external reset after CONF_DONE goes high. Another is to start the external reset(POR) even when configuration, but need to make sure the low external reset time is longer than the configuration. Is it a potential issue when external reset starts but configuration is not finished. or how to understand the all the I/O are tri-stated when configuration, as I indicated above. thanks.
