12 years agoFPGA external reset
hi, I am using Cyclone III,and I'd like to have my own external reset.but I am not sure when to safely insert external reset ASAP. Do I have to use it after CONF_DONE goes high? i...
12 years agoHi There!
If you have a reset controller that can monitor the CONF_DONE pin, you should be fine. Another would be to determine how long the configuration time takes. I did this with an EPF10k10, which came in somewhere around 300ms. I then used a standard reset-controller that would pull reset low for about 500ms, well exceeding the 300ms configuration time. Once the FPGA is configured, you'd just have a 500ms reset controller. Hope this helps, -Mux
