16 years agoFpga ethernet voltage levels
Hey everybody, I am transmitting ONLY from the FPGA without PHY chip ( are implemented the basic PHY functions on the FPGA ), also i am using isolation ( transformer ). The fpga Cyclone I ...
16 years agoUsing impedance matching resistors already creates a 1:1 divider. If you want to lower the voltage further, use a divider instead of series resistors. It should have 50 ohm single ended/ 100 ohm differential output impedance towards the filter/transformer.
I don't see a problem. It's basically the same technique used for 3R LVDS resistor networks.
