EEren's avatar
EEren
3 years ago
FPGA doesn't run after pof file programming.
The chip - MAX10M50SAE144. When I program sof file - it runs OK. When I program pof file - it doesn't run.
nCONFIG - pull-up, CONFIG_SEL - pull-down, CONFIG_DONE - pull-up.
What could be a problem?
  • Hi EEren,
    I wish to follow up with you on this case. Do you still have further inquiries on this issue? Please feel free to let me know if there is any concern so that we could further assist you.
    Fakhrul
  • FakhrulA_altera's avatar
    FakhrulA_altera
    Hi EEren,
    Fakhrul
    • EEren's avatar
      EEren
      Thank you.
  • Farabi_Altera's avatar
    Farabi_Altera
    Do you have scope shot for below signals:
    1. nCONFIG
    2. nSTATUS
    3. CONF_DONE
    4. VCC, VCCA, VCCIO
    How did you generate the .pof? Can you make sure the Quartus version is same?
    regards,
    Farabi
    • EEren's avatar
      EEren
      Thank you. The problem was a missing pull-up on nSTATUS.
