EEren
3 years agoFPGA doesn't run after pof file programming.
The chip - MAX10M50SAE144. When I program sof file - it runs OK. When I program pof file - it doesn't run. nCONFIG - pull-up, CONFIG_SEL - pull-down, CONFIG_DONE - pull-up. What could be a problem?...
- 2 years ago
Hi EEren,
I wish to follow up with you on this case. Do you still have further inquiries on this issue? Please feel free to let me know if there is any concern so that we could further assist you.
Fakhrul
Farabi_Altera
3 years agoHello,
Do you have scope shot for below signals:
- nCONFIG
- nSTATUS
- CONF_DONE
- VCC, VCCA, VCCIO
How did you generate the .pof? Can you make sure the Quartus version is same?
regards,
Farabi
EEren
3 years agoThank you. The problem was a missing pull-up on nSTATUS.
