8 years agoFPGA Development Board - strange shift operation behavior
My development board based on: Cyclone IV EP4CE10E22C8N Quartus: 17.0.0 Lite Edition top-level entity code:
module led4_reg(clk, led);
parameter BASE_LED_SEQUENCE = 12'b000011101101...
8 years agoreg led;
reg circle_count;
always@(circle_count or led) begin
if (circle_count == 4'd0) begin
led = BASE_LED_SEQUENCE;
end
else begin
led = led << 1;
end
end
This is very inefficient logic for variables defined as registers. You have built a change detector on circle_count[3:0] that will trigger an asynchronous clocking of the led[11:0] registers when it triggers. Why not just add the statement: led <= circle_count == 4'd0 ? BASE_LED_SEQUENCE : led << 1; into the main loop, so it looks like this: always @(posedge clk or negedge reset)
begin
if (!reset)
begin
count <= 28'd0;
circle_count <= 4'd0;
led <= 12'b0;
end
else
begin
if (count == 1'b1)
begin
count <= 28'd0;
circle_count <= circle_count == 4'd12 ? 4'd0 : circle_count + 4'd1;
end
else
count <= count + 28'd1;
end
end
which I think is a lot easier to follow.
