8 years agoFPGA Development Board - strange shift operation behavior
My development board based on: Cyclone IV EP4CE10E22C8N Quartus: 17.0.0 Lite Edition top-level entity code:
module led4_reg(clk, led);
parameter BASE_LED_SEQUENCE = 12'b000011101101...
8 years ago --- Quote Start --- Try this code out. I just modified it to add the reset and logic to store initial value.
1,2,3,4: led <= (led << 1);
--- Quote End --- Same result: 1,2,3,4 = 0; With D-latch same result:
module led4_reg(
input clk,
input rst,
output reg led
parameter BASE_LED_SEQUENCE = 12'b000011101101;
reg led_value;
reg circle_count;
reg count;
always @(posedge clk or negedge rst)
begin
if (!rst) begin
count <= 0;
circle_count <= 0;
end else begin
count <= count + 1'b1;
if (count == 1) begin
count <= 1'b0;
circle_count <= circle_count + 1'b1;
end
if (circle_count == 12)
circle_count <= 0;
end
end
always @(led) begin
led_value <= led;
end
always @(circle_count or led_value)
begin
case (circle_count)
0: led <= BASE_LED_SEQUENCE;
1,2,3,4: led <= (led_value << 1);
5: led <= 12'b110110100001;
6: led <= 12'b101101000011;
7: led <= 12'b011010000111;
8: led <= 12'b110100001110;
9: led <= 12'b101000011101;
10: led <= 12'b010000111011;
11: led <= 12'b100001110110;
default: led <= 12'b000_000_000_000;
endcase
end
endmodule
if I use:
1,2,3,4: led <= led_value;
it will get previous data.
