16 years agoFPGA-DAC PCB Design
Hi, I' m using Cyclone III FPGA (EP3C16Q240) and DAC5675A from TI to build an Arbitrary Waveform Generator. I' m currently designing the PCB that has to be limited to 2 layers and I have a few proble...
16 years agoHi FVM and thanks for your reply. Can you please explain what do you mean by "good differential output amplifier design" ? In my project I have the differential outputs of the DAC driving an opamp and then the SMA output connector. I intend to place a lot of vias across the output lines and also isolate them from any digital circuitry on my PCB, in order to reduce noise. Is there anything else that has to be taken care of?
