FPGA configuration FPP
To answer your question. Yes, to check whether the configuration is success or having some error can be detected by monitoring nSTATUS/CONF_DONE/INIT_DONE pins. For more information, if the FPGA is configured in FPP mode using a file generated for the wrong package, the possibility of the FPGA Fail to configure is high.
Hope that answers your question.
Nazrul Naim
- Gauthier_Auvray3 years ago
Not sure to understand your answer.
Do you mean that the FPGA will be configured with the file generated with the wrong package without reporting error on nSTATUS/CONF_DONE/INIT_DONE? (in that case the FPGA will will not be functionnal since pinout is different).
Or do you mean that the FPGA is able to detect that the file does not match the FPGA package and will report it on nSTATUS/CONF_DONE/INIT_DONE pins?
Gauthier
