Celia
6 years agoFPGA can't boot from serial flash (MT25QL128) with rpd file downloaded
Recently we meet a problem about flash boot up, in our design, we use MT25QL128 serial flash as configuration device in AS mode.
we can download jic file and boot up from jic file successfull...
YuanLi_S_Intel
6 years agoHi Celia,
Can you try to remove the CRC value located at the back? Also, you need to reboot the device for new design to boot up.
Thank You
- Celia6 years ago
Thanks for your response. Every time when we download the binary file to flash, our software will check the crc value. After we download the binary file to flash, I will power down, then power up again, but the FPGA can’t boot. I believe the rpd file is already binary file, do I need to use some ways to convert it to binary file again?
Celia
