16 years agoFPGA board
Hi everyone!, First of all, I'm new to the forum. I've tried searching for what I was looking for but didn't find it. I thank you for reading my subject. I'm currently developing an FPGA b...
16 years ago1 - It's difficult to know if the FPGA you've selected is "big enough" (has enough logic elements). That depends entirely on what you are going to do with it. Typically what I do is try some test projects first with what I think is a fair representation of the amount of logic I'll be using and make my decision based on that.
2 - The FPGA should be handle all of the interfaces you've listed. You will of course need external components to support ethernet and RS-232. Are you sure you don't want to use a dev kit? Like this one: http://www.altera.com/products/devkits/altera/kit-cyc3-starter.html You could just create your own mezzanine board and connect it through the HSMC (available from Samtec). Jake
