14 years agoForce a signal in the output of a logical gate: destructive?
Hi all! I've got a question that seems rather stupid at first: what happens if I try to put a signal in the output of a FPGA logic? Let me explain why this problem could happen: I have to ...
14 years ago --- Quote Start --- I've got an error: Pin "name" is stuck at GND. --- Quote End --- You'll get that for logic like; my_output <= '0'; I do that for unused outputs, and then ignore the warning. --- Quote Start --- In my design, and in normal operation, this pin will be all the time at GND. But If there is a SEU at a bad place, there is a possibility it goes high, so it is usefull (because the purpose of this pin is to detect the SEU...) My question is: is the program implement exactly the schematics, or does it detect this "error", and the do some optimization? --- Quote End --- I suspect it will optimize the logic and delete it. --- Quote Start --- I've got an other warning just after saying that this pin does not drive any logic, so I'm a bit afraid that the system removed for optimization purpose this part of my design... --- Quote End --- Sounds like it. --- Quote Start --- If yes, is it possible to force it to implement my design exactly? (I'm currently using the schematic editor to implement my design...) --- Quote End --- How about; You have two pins; my_input and my_output. my_output <= '0'; will generate the FPGA driven low value my_input can be physically tied to my_output on the PCB (use two BGA pads that are right next to each other). Drive the my_input signal to your voting logic. If you get a SEU in the my_output or my_input path, you'll detect it. Cheers, Dave
