14 years agoForce a signal in the output of a logical gate: destructive?
Hi all! I've got a question that seems rather stupid at first: what happens if I try to put a signal in the output of a FPGA logic? Let me explain why this problem could happen: I have to ...
14 years agoThanks for your replie.
But I've got a SRAM behind the FPGA, so the loss of voltage caused by the R will weaken the signal, maybe to the point that the SRAM cannot decode it anymore, no? When you mean that I can limit the current, does that mean that the FPGA can handle some "reverse" current without burning? By the way, i've got an other question. Is it possible to make a modified IO buffer so it act like this: -> You can set the direction (input or output) -> You can disable the output if in output mode (so, in output mode, it becomes a tristate gate)? Because when I see the block diagram of the output pad of the FPGA (ug_low_level.pdf), I really have the impression that it's possible. But the primitiv ALT_IOBUF seems to activate the input when it put the output buffer in high impedance.
