13 years agofor module 'cpu' did NOT run successfully.
hello
I tried to create a new component with the SOPC Builder, this component is in the form of a verilog file "rtp_tx.v" which must have two interface, avalon master interface to connect with ddr sdram interface and avalon Slave connect with the cpu. but when I added the avalon master interface always displays errors. So I added another component in verilog avalon master, and the component rtp_tx.v I add a single interface avalon slave that I connect with the avalon master interface component avalon master and I connect 'avalon master interface to interface Slave ddr sdram. it works and the generation is succesfull, but there's always this errorERROR:slave data width (26) for slave avalon_master_0/avalon_slave_0 unexpected Error: Generator program for module 'cpu' did NOT run successfully.
I do not know if what I did is correct or not because I am a beginner in this field9 Replies
it s ok i resolve the probem
thank you - Altera_Forum
Hi
i chek the signals used for different interface,I noticed that there's an address with widhth is 26 bits, my data is 32 bits widhth what can i do in this case ?? thank you - Altera_Forum
Okay, in that case check the signals used for the different interfaces in the component editor. You are probably using the wrong signal as readdata or writedata. Maybe an address vector instead of data?
Nut in my verilog file i defined "data input [31:0] payload_in_data;" it alredy 32 bit
edit your verilog file. You'll probably have to re-run the component editor too, to have it pick up the new vector size.
haw can i change data to 32 bit ??
thank you fo your help - Altera_Forum
change it to 32 for example.
and what's the solution for this ??
As the error message suggests you have a weird size for your data vector (26 bits). The supported data sizes are 8,16, 32, 64, 128, 256, 512 or 1024 bits
