15 years ago
floating point operating in vhdl (fixed_pkg)
Hi all;
I have write a code using fixed_pkg. It compile successfully in quartus, but when I try to simulate in ModelSim an error occur.
library ieee;
library ieee_proposed;
use work.fixed_pkg.all;
use ieee.numeric_std.all;
entity fix is
port (clk: in bit;
nprev: in integer range -127 to 127;
ip1: out ufixed (8 downto -9));
end fix;
architecture fix of fix is
signal n1: ufixed (4 downto -4);
begin
process(clk)
begin
if (clk'event and clk='1') then
ip1 <= (to_ufixed(0.483,n1)) * (to_ufixed(11,n1));
end if;
end process;
end fix;
This is the error in ModelSim:# Compile of fix.vhd failed with 2 errors.# Compile of fix_tb.vhd failed with 2 errors.# Compile of fixed_float_types_c.vhdl was successful.# Compile of fixed_pkg_c.vhdl failed with 1 errors.# Compile of fixed_synth.vhdl failed with 2 errors.
This the error when I expand it:
** Error: H:/altera/mul_try_tb/fix_tb.vhd(2): Library ieee_proposed not found.
I have add all the fixed_pkg in the project (in quartus). Need your helps..
    if you just run vcom it will add it to the work libarary. To add a file to the specific library, you need the -work option
    vcom fixed_float_types_c.vhdl -work ieee_proposed
    vcom fixed_pkg_c.vhdl -work ieee_proposed
    I write in the modelsim command window for create the ieee_proposed;
    vlib ieee_propose
    vcom vcom fixed_float_types_c.vhdl
    There are no error for line 1 and 2. But, in line 3 this error occur:# ** Error: (vcom-11) Could not find ieee_proposed.fixed_float_types.# ** Error: fixed_pkg_c.vhdl(23): (vcom-1195) Cannot find expanded name "ieee_proposed.fixed_float_types".# ** Error: fixed_pkg_c.vhdl(23): Unknown expanded name.# ** Error: fixed_pkg_c.vhdl(25): VHDL Compiler exiting# C:/altera/10.1/modelsim_ase/win32aloem/vcom failed.
    What my false?..thanks for reply
    on the modelsim command window (or in a tcl or do file):
    vlib floatfixlib
    vcom fixed_float_types_c.vhdl -work floatfixlib
    vcom fixed_pkg_c.vhdl -work floatfixlib
    etc.
    How to create the floatfixlib? Do you have any other idea for avoid the error..
    thanks for reply
    you will need to create the floatfixlib, as I dont think the starter edition ships with it.
    I use ModelSim Altera Starter Edition 6.6d..After I remove the ieee_proposed library, this error occur in ModelSim:
    ** Error: H:/altera/mul_try_tb/fix.vhd(3): Library floatfixlib not found.
    ** Error: H:/altera/mul_try_tb/fix.vhd(4): (vcom-1136) Unknown identifier "floatfixlib".
    Thanks for reply
    what version of modelsim?
    newer versions of modelsim have the fixed_pkg in the floatfixlib library, so I would delete all references to ieee_proposed and the fixed_pkg in the work library.
