15 years agofloating point operating in vhdl (fixed_pkg)
Hi all; I have write a code using fixed_pkg. It compile successfully in quartus, but when I try to simulate in ModelSim an error occur. ------------------------------------------------------...
9 years agoI did as Tricky suggested and both my Quartus and ModelSim projects compile! I had to rename "ieee_proposed" to "ieee" as suggested by flz47655.
Just so I understand why this works, correct me if I'm wrong: - Quartus compiles the 1993 (compatible) fixed_pkg into its ieee library - ModelSim also compiles the 1993 (compatible) fixed_pkg into its ieee library, ignoring its 2008 version since I used the _c.vhdl files for the fixed_pkg - this would not have worked if the source files "fixed_float_types" and "fixed_pkg" were named the same in both projects since ModelSim has its own version of the files
