15 years agofloating point operating in vhdl (fixed_pkg)
Hi all; I have write a code using fixed_pkg. It compile successfully in quartus, but when I try to simulate in ModelSim an error occur. ------------------------------------------------------...
9 years agoThis thread is the closest I've found to addressing my issue, so I hope you don't mind me reviving it. I am using fixed_pkg in my VHDL design to do fixed point arithmetic. I compiled it into my Quartus work library so didn't create the ieee_proposed library:
library IEEE; use IEEE.std_logic_1164.all; use IEEE.numeric_std.all; use work.fixed_pkg.all; My design compiles and synthesizes successfully in Quartus 16.1.1 Standard, but not in ModelSim 10.5a: Error: (vcom-11) Could not find work.fixed_pkg. Now I've read that I can change the location of fixed_pkg from "work" to "ieee" since ModelSim supports it. However, the compilation of my project is heavily scripted, so I need to use the same source files for both the Quartus and ModelSim synthesis. How can I do this?
