15 years ago
floating point operating in vhdl (fixed_pkg)
Hi all;
I have write a code using fixed_pkg. It compile successfully in quartus, but when I try to simulate in ModelSim an error occur.
library ieee;
library ieee_proposed;
use work.fixed_pkg.all;
use ieee.numeric_std.all;
entity fix is
port (clk: in bit;
nprev: in integer range -127 to 127;
ip1: out ufixed (8 downto -9));
end fix;
architecture fix of fix is
signal n1: ufixed (4 downto -4);
begin
process(clk)
begin
if (clk'event and clk='1') then
ip1 <= (to_ufixed(0.483,n1)) * (to_ufixed(11,n1));
end if;
end process;
end fix;
This is the error in ModelSim:# Compile of fix.vhd failed with 2 errors.# Compile of fix_tb.vhd failed with 2 errors.# Compile of fixed_float_types_c.vhdl was successful.# Compile of fixed_pkg_c.vhdl failed with 1 errors.# Compile of fixed_synth.vhdl failed with 2 errors.
This the error when I expand it:
** Error: H:/altera/mul_try_tb/fix_tb.vhd(2): Library ieee_proposed not found.
I have add all the fixed_pkg in the project (in quartus). Need your helps..
