9 years agoFloating Point Calculation MegaWizard
Hi Guys, I am interested to use floating point calculation megawizard - ALTFP_ADD_SUB. The only thing that I change in MegaWizard is single precision but I'm getting somthing other like ...
9 years agoFound the problem!
For some reason, the name that I gave to the entity ("Floating Point_Add") was hidden at the end of the " Floating Point_Add.vhd" file (inside "Floating Point_Add.qip"). to get to him, you simply need to scroll down to the end of the file (at the beginning of the file the " Floating_Point_Add_altbarrel_shift_35e" entity appear which make the confuse with the " distance". Thnaks anyway... Idan
