9 years ago
flashing EPCQ128 instead of EPCS128 since discontinue of EPCS
Since Intel/Altera is pulling the plug on the EPCS manufacturing line (See here (https://www.altera.com/content/dam/altera-www/global/en_us/pdfs/literature/pcn/pdn1708.pdf3jgrzziwafj40vwb8btg)) I need to move to EPCQ. I'm working with Remote Update and serial flash loader IP's on Quartus 13.1 (which I flash the RBF file). Except for re-producing these IP's with EPCQ instead of EPCS, do I need to do anything else? Will the RBF can be flashed to the EPCQ?
1 Reply
    When you create the .rbf files in the programming file conversion utility, you'll have to adjust the conversion settings appropriately. Other than that, it should work fine I would think.
