9 years agoflash usage
I'm trying to follow the Altera DE2-115 with Linux sample from this link (http://www.alterawiki.com/wiki/linux_with_mmu_on_veek/t-pad#unfortunately.2c_if_you_don.27t_have_veek.2ft-pad_kit.2c_but_you_...
9 years agodebug output
nios2-flash-programmer --debug --epcs --base=0x0a001800 tPad_Selector.flash
Using cable "USB-Blaster ", device 1, instance 0x00
Resetting and pausing target processor:
OK
Processor data bus width is 32 bits
Looking for EPCS registers at address 0x0A001800 (with 32bit alignment)
Initial values: 0001703A 04C00074 9801483A 9CFFF804 983FFD1E 0000203A
Not here: reserved fields are non-zero
Looking for EPCS registers at address 0x0A001900 (with 32bit alignment)
Initial values: 92400237 4A40100C 483FFD26 90000135 92400237 4A40200C
Looking for EPCS registers at address 0x0A001A00 (with 32bit alignment)
Initial values: 108001C4 1004D0FA 002EE03A 003F9C06 002EE03A 003F9506
Looking for EPCS registers at address 0x0A001B00 (with 32bit alignment)
Initial values: 00000000 00000000 00000000 00000000 00000000 00000000
Not here: SPI_SLAVE_SEL has 0 valid bits (should be between 1 and 16)
Looking for EPCS registers at address 0x0A001C00 (with 32bit alignment)
Initial values: 00000000 00000000 00000260 00000000 00000000 00000001
Valid registers found
EPCS signature is 0x16
EPCS identifier is 0x010216
No EPCS layout data - looking for section
Unable to use EPCS device
Leaving target processor paused
