9 years agoflash usage
I'm trying to follow the Altera DE2-115 with Linux sample from this link (http://www.alterawiki.com/wiki/linux_with_mmu_on_veek/t-pad#unfortunately.2c_if_you_don.27t_have_veek.2ft-pad_kit.2c_but_you_...
9 years ago --- Quote Start --- Hi, There are few possibilities based on the error message, usually this is due to the flash programmer not able to find the EPCS flash. Please check the base address, and make sure the HW connections are OK. --- Quote End --- The HW connections seem OK because jtagconfig reports the connection is there. But how can I check the base address? I don't have much more than what is online about DE2-115. I got the actual board but I don't think that I got a CD or any other "reference designs". I just want to try and run Linux with it.
