9 years agoflash usage
I'm trying to follow the Altera DE2-115 with Linux sample from this link (http://www.alterawiki.com/wiki/linux_with_mmu_on_veek/t-pad#unfortunately.2c_if_you_don.27t_have_veek.2ft-pad_kit.2c_but_you_...
9 years agoWhat hardware are you using? Is it a DE2-115 or are you simply using that link for reference?
If it's you own hardware - what EPCS device are you using? And, if necessary, does it have an entry in the nios-flash-override file? If you're on a DE2-115 board then I suspect you've specified your base and/or boot addresses wrong when you've configured your Nios. Refer to one of the examples that come with the kit for reference. Cheers, Alex
