16 years agoFLASH programming M29W640FB
I am developing a method of programming FLASH in order to help production. the device is an AMD M29W640FB (8 MByte device). Initially I used the 'Nios FLASH programmer' but it was not able to f...
16 years agoThanks
that command worked. the system has always been able to read the CFI table. I have compared what is read from the table with what the chip specification says is actually in the chip and they match. here is my script: nios2-flash-programmer --device=2 --instance=0 --debug --sidp=0x02821038 --id=0x71d36849 --base=0x00000000 --width=8 --program ./flash/dir.flash The system had trouble erasing three 8KByte sectors - I had to invoke the script three times before all sectors were erased. Then the system appeared to 'test' the writtability of the flash and reported the following: Program sequence: Write address 0x00000000 <= 0xF0 Write address 0x0000AAAA <= 0xAA Write address 0x00005555 <= 0x55 Write address 0x0000000F <= 0x25 Write address 0x0000000F <= 0x00 Write address 0x0000000F <= 0x30 Write address 0x00000000 <= 0x29 Read address 0x0000000F => 0xFF Program failed at offset F Leaving target processor paused /****/ It appears as though location 0xFF is still in the erased state. So the write to that location did not work. additionally the addressing seems incorrect. the algorithm writes 0xAA to location 0x0000AAAA // then 0x55 to location 0x00005555 // then writes 0x25 to location 0x0000000F // in the specification for this chip it indicates the algorithm should be: write: 0xAA to location 0x00000AAA // then 0x55 to location 0x00000555 /then wirte <the intended data> to location <the intended address> you see - the Nios2 programmer is writting to the incorrect location.
