16 years agoFlash Programming in Command-Line Mode
Hi, I have integrated the .elf contents into the .sof file; that is, this .sof file include both the hardware and software. I can also use Nios II Flash Programmer tool to program this .sof file to f...
16 years agoThere are a few methods for doing this. However, the method I use is to copy over only a few extra files:
http://www.alteraforum.com/forum/showthread.php?t=20030&referrerid=2226 and continue to use the nios2-flash-programmer. You can either write a little batch file or script to do this or do something more fancy. For help on the nios2-flash-programmer command line options: http://www.altera.com/literature/hb/nios2/edh_ed51004.pdf Jake
