11 years agoFlash Programmer Issue
Hi, I do have a strange behavior with the flash programmer: I have two projects, built roughly in the same way, to be programed on to 2 different FPGA boards featuring each an EPCS device. ...
11 years agoYes Mini@nB
Everything is built from the xml file generated by the GUI and called <project_name>.flash-settings The GUI shows the file generation and programming commands for both elf and sof files and everything looks correct. The two .flash-settings files (for the 2 projects) are absolutely identical, except for the project name and cpu address (as expected). But ... one generates a command which uses only one .flash file identical for both .elf and .sof while the other (the good one) adds a "_1" to the .flash file name allowing me to get the two .flash files that can be sent to a remote location for upgrade. I'm guessing the difference may come from another file in the project (.bsp, .sopc_info, .qpf ...) but I've been able to figure which one out. Thanks. jylo
