11 years agoFlash Programmer Issue
Hi, I do have a strange behavior with the flash programmer: I have two projects, built roughly in the same way, to be programed on to 2 different FPGA boards featuring each an EPCS device. ...
11 years agoCan you specify what kind of GUI? Is it TCL command script running in the background? To convert either elf or sof to flash, you can find the command in here https://www.altera.com/content/dam/altera-www/global/en_us/pdfs/literature/hb/nios2/edh_ed51004.pdf. Hopes it will help you to understand the command.
