15 years ago
Flash memory problem
Hello, is it true that I cannot write 1MB of data into flash memory (4M)?
I am using Altera DE2 Board. My code is as follow:
--- Quote Start ---
# include <stdio.h># include <stdlib.h># include <unistd.h># include "altera_avalon_pio_regs.h"# include "system.h"# include "alt_types.h"# include "sys/alt_dma.h"# include "sys/alt_flash.h" # include "sys/alt_flash_dev.h"
# define loop 262144# define size 1048576
int main ()
alt_flash_fd* fd;
int ret_code, i;
int *src_ptr;
int *dest_ptr;
src_ptr = SDRAM_BASE + 0x200000; //Location of data written in SDRAM
dest_ptr = EXT_FLASH_BASE; //Location of data written in flash
//Open flash
fd = alt_flash_open_dev(EXT_FLASH_NAME);
if(fd!=NULL)
//Generate data into SDRAM
for(i=0;i<loop;i++)
IOWR(src_ptr, i, i);
//Write data into flash
ret_code = alt_write_flash(fd, 0, src_ptr, size);
if(ret_code != 0)
printf("Error writing into flash: %d\n", ret_code);
exit(1);
//Read from flash
for(i=0;i<loop;i++)
printf("Value at %X is %d, written at is %d\n", dest_ptr, *dest_ptr, IORD(src_ptr, i));
dest_ptr++;
}else
printf("Unable to open flash\n");
exit(1);
alt_flash_close_dev(fd);
return 0;
--- Quote End ---
I keep on getting error msg: Cannot write into flash and the error code is -5. pls help me. i am not sure whether is my coding problem or writing 1MB into flash is a special case. pls help! thanks!
    The only explanation I can give you is that the second flash block is locked.
    You can read the lock status and possibly unlock it in order to allow erase and write operations. I don't know if the HAl driver supports these operations; if not, you must make it manually with direct IOWR/IORD; it's not difficult, but you must search the required command sequence in the flash device datasheet.
