HAlex
3 years agoFlash Loader IP not loaded on device 1
Hello
I am using EP4CGX150CF23C8N with EPCQ128ASI16N flash as AS a configuration device.
When I am trying to program jic file to the flash IC with Intel USB blaster II - I immediately get messa...
NurAiman_M_Intel
3 years agoHi Alex.
- How long is the timing when using USB Blaster and Terasic?
- Have you try to use another USB blaster? Is the timing still slower?
- Can you provide us your schematic, from the same part as the screenshot you just shown?
Aiman
- HAlex3 years ago
Hello Aiman
1. Programming same jic file with:
USB blaster II running on 16Mhz (after I run: jtagconfig --setparam 1 JtagClock 16M) - 3 minutes 39 seconds.
Terasic USB blaster (running on default speed, should be 6Mhz) - 56 seconds.
2. Don't have another Altera USB blaster II for compare.
3.
Micron flash is not assembled.
Thank you
Alex
