Flash Loader IP not loaded on device 1
The Intel® FPGA Download Cable II has a default TCK frequency of 24 MHz. However, it is mentioned in the Userguide that for some, signal integrity and timing prevent operating at 24MHz. Hence we recommend to lower the TCK frequency of the download cable. You may refer to below UG.
Aiman
Hello
As I wrote I did performed reduction of the operating frequency to 16Mhz but even with this frequency USB blaster II working much slower than Terasic USB blaster running on 6Mhz. This cause us difficulties using USB blaster II in mass production (and we don't have enough Terasic USB blasters).
Anyway, I am not sure that the issue is a signal integrity (unless it is inside FPGA). This is because JTAG path running on 24Mhz configuring SOF file without problem.
And the path between FPGA and flash running on 40Mhz configuring FPGA smoothly.
Maybe the problem is with SFL IP that can't run on 24Mhz??
What do you think?
Thank you
Alex
