12 years agoFlash CFI in SoPC Builder
Hi All, I am trying to connect 22x8 bit (4MByte) flash memory on DE2 board via flash cfi controller. If I connect it to the Avalon tri-state bridge I got the following error: "signal tri_state ...
11 years agoHello guys!
I'm trying to execute the memory test template. I select the option to test flash. I have checked in the system.h file that the name of the flash is /dev/ext_flash. But when I type in the same name in the nios console, it shows an error saying : could not open "/dev/ext_flash" any idea how to eliminate this error? Thanks in advance.. any advice is welcome.
