12 years agoFlash CFI in SoPC Builder
Hi All, I am trying to connect 22x8 bit (4MByte) flash memory on DE2 board via flash cfi controller. If I connect it to the Avalon tri-state bridge I got the following error: "signal tri_state ...
12 years agoYes ! you were right.
You use SOPC. which version of quartus do you use ? version 10 and 11 are transitions from SOPC to QSYS I reopen an old project on Quartus II v9.0 wich is similar, change the Data with to 8, 16, 32 I get no error like you :-/ (just overlap error for 32 bit width data) It is strange that in your tristate bridge allow you do NOT share the "data" bus ; since data are always shared !?! Have you build your SOPC yourself, or have you modified an existant SOPC ? You are not alone : http://www.alteraforum.com/forum/showthread.php?t=43230&p=178794#post178794 (not resolved here) Tristate bridge in QSYS (new SOPC from Quartus) is more difficult, but possible. hard to help you, Good luck !
