17 years agofixed-point tips
Hi I have some experience with Quartus, but in the past have only worked on projects that implement very basic boolean expressions (like generating pulses with user defined widths and delays)....
17 years agoThe new VHDL floating point packages actually have all necessary means for typical DSP problems as in your example. But I used my own functions for scaling of products similar to the one you discussed above up to now. I didn't even try, if they synthesize with Quartus without problems. Basically, the method works for arbitrary fixed point and fractional numbers, if you use a variable shift factor in product scaling and additional saturation logic.
I show an example of a multiply with scaling and saturation for reference:FUNCTION MUL_ASL (X1,X2: SIGNED; N: INTEGER) RETURN SIGNED IS
VARIABLE P:SIGNED(X1'length+X2'length-1 downto 0);
BEGIN
P:=X1*X2;
IF P(P'left-1 downto P'left-N) /= 0 AND P>=0 THEN
P:= (others => '1');
P(P'left-N):='0';
ELSIF P(P'left-1 downto P'left-N) /= -1 AND P<0 THEN
P:= (others => '0');
P(P'left-N):='1';
END IF;
-- Result length equals X2
RETURN P(P'left-N downto X1'length-N);
END; For fractional signed numbers with a -1..1 range, the shift factor has to be set to 1 to remove the double sign bit. Fast parallel division as lpm_divide is consuming a lot of resources. It can't be avoided sometimes, but in many cases other solution can be found. For "slow" division applications, I generally use a serial divider, that needs one clock cycle per result bit. Another options is a 1/x look-up table.
