17 years agofixed-point tips
Hi I have some experience with Quartus, but in the past have only worked on projects that implement very basic boolean expressions (like generating pulses with user defined widths and delays)....
17 years agoOops, apologies... VHDL.
I've made a little progress. I've written a little function that multiplies two 16 bit unsigned integers, which results in a 32-bit unsigned integer. The function then just drops the 16 LSBs which results in the scaled answer. So this works fine for unsigned inputs whose 'real' value is =< 1. I don't know how general this is for values > 1... probably not. For signed values I suppose just a little extra logic is needed to test the sign bit and derive the appropriate sign bit for the result. The next element I need to figure out is the division part. Assuming (A1*A2) (the divisor) is not a tidy factor of 2 then would inverting then multiplying work. Is there a simple approximation for 1/x using a Taylor expansion or some other simple way? I don't think it has to be too accurate. Thanks in advance for any pointers, Kurt
