9 years agoFitter resource usage summary
Hi I get the following utilization in Fitter resource summary: that Clock pins - 3/2(150%) Dedicated Input pins 7/4 (175%) What does this exactly mean? Does this mean 3 cloc...
9 years agoHow far through compilation does the project get? Can you post some of the report files generated when you run through project through Quartus? The "{}.sta.rpt" & "{}.fit.rpt" should do.
It's not clear from what you've written whether there's an issue. The fitter may chose to use dedicated clock input pins for non clock signals. Cheers, Alex
