9 years agoFitter resource usage summary
Hi I get the following utilization in Fitter resource summary: that Clock pins - 3/2(150%) Dedicated Input pins 7/4 (175%) What does this exactly mean? Does this mean 3 cloc...
9 years agoThanks Alex
The device I am using has more I/O pins and the design only needs one clock pin; the fitter is choosing these pins for some reason I can always change them in Pin Planner to other User I/O pins and make the clock and dedicated pin free. I mean if it is not coming as Error(red) should this be a problem I don't understand if the device has only available two clock pins how can it use 3??
