8 years agoFitter Error with LOANER option on cyclone V
HI I'm working with LOANER option for can communicate the HPS UARTbut when i compile the system generated by qsys i have errors in the fitter part. The error is the next: Error (179000)...
8 years agoHi Eivann,
ERROR is because of the device IO constrain. 1.The device which you have selected is having only 145 IO pin's. And you are using 206 IO pins in design. 2,Select the device which is matching your design requirements. Best Regards, Anand Raj Shankar (This message was posted on behalf of Intel Corporation)
