10 years agoFitter error for LVDS o/p ports
I am currently executing one vhdl code in quartus. I am getting the following error during fitter. " error (169175): pin %signal% with lvds i/o standard needs a differential output buffer which is not available on location ae13. "
Can you suggest some workaround for this . Thanks and regards Mahima Satsangi
Thanks for your answer. It really helped. Now Fitter problem is solved.
Re-assign the signal to a pin that does contain the appropriate buffer for the I/O standard you're trying to use.
If you must use that pin then all you can do is change the I/O standard to one that is supported by it. Cheers, Alex
