10 years agoFitter error for LVDS o/p ports
Hi, I am currently executing one vhdl code in quartus. I am getting the following error during fitter. " error (169175): pin %signal% with lvds i/o standard needs a differential output...
10 years agoRe-assign the signal to a pin that does contain the appropriate buffer for the I/O standard you're trying to use.
If you must use that pin then all you can do is change the I/O standard to one that is supported by it. Cheers, Alex
