Seadog
7 years agoFitter error due to 'get_combs' command in .sdc file
I am getting a fitter error caused by a 'get_combs' command in the .sdc file; the get_combs command is part of a create_generated_clock command: -source [get_combs {blah_blah_blah\ ...
Seadog
7 years agoThanks. I have that document, but as I wrote above it does not mention a 'get_combs' command. And any time Quartus/Timing Analyzer has occasion to write the .sdc file, it puts that 'get_combs' command back in there. Replacing the 'get_combs' instances with 'get_nets' seems to work, but I don't understand why the tool inserts a command which it can't process; it seems to me that this is a bug which needs to be addressed.
