12 years agoFIR interpolator
Hello guys !! I'm trying to understand the FIR compiler interpolator. I have a complex signal clocked at X MHz. Now I want to have it interpolated by a 3x factor so that the output frequen...
12 years ago --- Quote Start --- I am using the altera fir compiler megawizard. I've read the userguide but it seems not so clear what for sample rate is intended. --- Quote End --- if the entry is for input sampling rate that is clear. if it says filter sampling rate then I expect it to be the output rate.
