FIR II core IP outputs incorrect data.
- 5 years ago
Would you mind to help opening a new thread on this. Thank you very much.
Thanks for your update. yes, the signed binary, the MSBits = sign bit. Please allow me some time to look into your shared test bench. I will be out of office and back on next Tuesday due to local Public holiday. I will keep you posted on the progress by mid of next week or as soon as there is any valid finding. Please ping me if you do not hear back from me.
Thank you.
- CheepinC_altera5 years ago
Sorry for the delay. As I understand it from your screenshot, seems like the source data = undefined in your simulation. Sorry as I am not very familiar with VHDL and could not really further edit your test bench for testing.
To facilitate your debugging, I have generated a simple simulation example from the IP with 16 bits coeff and 16 bits input signed data using A10 in Q17.0Std. There seems to be no FIR .qsys file in your .rar, and thus I am using some dummy setting in my example. You may refer to the fir0.qsys in the test.zip. I have edited the test bench to feed constant data. From the Modelsim simulation, seems like I am able to get valid output from the IP as shown in the screenshot.
I have attached the ZIP of the simulation folder. You can run the simulation by doing the following:
1. Change directory in Modelsim to \test\fir0_tb\fir0_tb\sim\mentor\
2. Type "source msim_setup.tcl"
3. Type "ld" to compile
4. Type "do wave.do" to populate the waveform
5. Type "run -all" to run the simulationYou may further customize from this example with your input data as well as target configuration.
Chee Pin- alperenpalp5 years ago
Sink valid signal is also high during the whole simulation. I assumed I assert the valid signal every time I got a data which is at 15 MSPS, in this simulation it seems like you're feeding 60MSPS by asserting the sink valid signal for every clock cycle. What am I missing?
Hello again
Thanks for your respose. I am going to look into it, but there is something that's confusing me about the results. The output is 7.5MSPS instead of 15 MSPS. Isn't it wrong. What am I missing here?
The reasons there is no qsys file is that I use the IP catalog directly. Should I use plaform designed instead?
