12 years agofir filter for fsk demodulator
Hi, i've realized an i_q demodulator for fsk message. The frequencies for the 0 and for the 1 are spaced 400Hz; the baud rate is up 200baud. The frequencies are in the audio range (for example F...
12 years agoadditionally you can design your fir as decimator since your 200KHz can be reduced right to 2*20 = 40KHz or so (say 50KHz) then you have decimation factor of 200/50 = 4
hence your filter mults will go down to 26 per filter
